checking injectors?
  • Thread starter Thread starter wshI_hd_1
  • Start date Start date Nov 28, 2004
W
wshI_hd_1
94
paulding, ga.
Nov 28, 2004
  • Nov 28, 2004
Ive got a promblem with my car that feels like the fuel pumps gone(give it gas and it bucks but doesnt go any where, and kinda spits and sputters), but i just replaced it with a 190lph and put fuel injector cleaner in it and it didnt do anything, but im getting fuel pressure when it does it so im thinking its injectors...question is, how do i check them to see if i have a bad injector?
HISSIN50
34
129
Nov 28, 2004
  • Nov 28, 2004
while running trouble codes, perform the cylinder balance test.
good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 29, 2004
  • Nov 29, 2004
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 for everything OK, or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at Walmart.
Funanin
356
Horsham, Pennsylvania
Nov 29, 2004
  • Nov 29, 2004
i was going to say check ur distributor cap, when i powerwashed my motor, I covered all the electrical connections, but water must have gotten into the distributor and messed it up. After a few days it went away tho.
eliot22
1,461
San Diego, CA
Nov 29, 2004
  • Nov 29, 2004
Could also be an electrical problem. First step is always pulling codes.
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
