Checklist for fuel pump problems.. Mini-how to?
triggz
1,218
Gadsden, AL
If the fuel pump will not prime at all when the ignition is turned to ON:
A) Check inertia switch in trunk. Red button should be pushed in a little.
B) Check 20a fuse #14 (in the corner) in the fusebox by the battery.
C) Check relay (Where?)
D) Check voltage at pump harness.. (What color wires are these/where is the connector?)
E) If pump is getting no voltage from step D, jump a 12v wire directly to pumps 12v lead to test pump manually (again, where is this?)
What else?
