chip
  • Thread starter Thread starter peter win
  • Start date Start date Aug 10, 2008
P
peter win
  • Aug 10, 2008
I have a 86gt cov stock , and I would like to put a surge perfomance chip that cost $199 but it is on sale now for $89 . Also I would like to change the rear end gears to 327 . What kind of perfomance would i get ?
Mustang5L5
Mod Dude
Feb 18, 2001
43,265
17,952
224
Massachusetts
Aug 10, 2008
  • Aug 10, 2008
Save your money. off-the-shelf chips don't do much. You are better off getting a custom tune after you get a decent amount of mods done.
Also, for a convertible, i'd go with 3.73's. The extra weight would need some more gearing
P
peter win
  • Aug 10, 2008
What is a custom tune , and what mods should i do without breaking the bank
Mustang5L5
Mod Dude
Feb 18, 2001
43,265
17,952
224
Massachusetts
Aug 10, 2008
  • Aug 10, 2008
If your car is stock. Don't worry about a chip or tune. There isn't much to be gained on a naturally aspirated car.
mods you can do are gears, shifter, pullies, exhaust, etc. Depends what direction you want to go.
MikeROD16
Miami, FL
Aug 11, 2008
  • Aug 11, 2008
i would say the first thing to do is get some heads and intake
Ill PM u about it.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Aug 11, 2008
  • Aug 11, 2008
Chips on Foxes for the most part are a huge waste of money. You can manually adjust spark timing in your driveway, and with an adjustable fuel pressure regulator, your A/F ratio. Also, down the road you will likely change your computer for a mass-air unit anyway, to compensate for big modifications.
Put 3.55 or 3.73s in it if its a stick car, 3.73 or 4.10s in it if its automatic.
The 86's have a very restrictive intake setup. Put exhaust on the car, then upgrade to CAI, followed by a 65-70mm TB. The upper intake can be swapped out for a later (87-93) upper, which flows better, and yet matches the bottom casting, which was the same for 86 on. The upper is a very easy bolt on swap, but if you want more flow, go upper/lower aftermarket or GT-40 style (Cobra, Explorer, or FRPP tubular).
Because its an 86, forget about new heads until you get new pistons, as the 86 has no valve reliefs on the pistons, and aftermarket heads will NOT work until you get that issue resolved, because of valve to piston interference.
Reactions: WonkeyDonkey
M
Headlights
  • Magnet86
  • May 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
Blown88GT
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
M
Paint and Body Restoration prob
  • Magnet86
  • Jul 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
2000xp8
