What I gained ? No hassles stemming from a malfunctioning choke. No running rich because of it. No choke slamming shut (had this happen at the drag strip with the 331 and it's sixpack setup with it's manual choke) when doing a burnout. No sticking in fast idle either. The butterfly does create some airflow restriction, how much is a 64 million dollar question though. All I know is I don't need one and simply taking 5 minutes to remove it is time well worth spending. The hole thru the throttle body that the choke rod passes thru on a Holley can be plugged by leaving the plastic bearing slide in place and screwing screw thru the hole. There's probably more gain here that I haven't thought of.
