Zooted_plus New Member Jan 14, 2003 152 0 0 Dublin, CA Mar 5, 2004 #1 Mar 5, 2004 #1 Where's the best place to run 12v for an electric choke? The stator wire off the alternator? What color is this wire on a '65? Thanks,
pabear89 Active Member Apr 15, 2003 2,126 0 46 High in the Hills of So Ca with the Voices in My H Mar 5, 2004 #2 Mar 5, 2004 #2 Not sure on 65, But I ran mine to the backup light connector on the engine loom. Get 12v key on. PB
crushnut New Member Apr 27, 2003 870 0 0 Oregon Mar 6, 2004 #3 Mar 6, 2004 #3 Zooted_plus said: Where's the best place to run 12v for an electric choke? The stator wire off the alternator? What color is this wire on a '65? Thanks, Click to expand... Be careful when hooking it up to the alternator, i did that once and connected it to the wrong one Ended up being hot all the time and drained my battery
G gp001 Founding Member Jun 30, 2001 4,401 0 66 So. Cal. Mar 6, 2004 #4 Mar 6, 2004 #4 I've always hooked electric chokes up using an oil pressure switch. That way they are only hot during start or when the engine is actually running.
