CJ Pony Service Open House 2010!
Steve@CJPony
5 Year Member
Mar 5, 2010
597
10
59
Harrisburg, PA
Now through March 31st, 2010: CJ Pony Service March Open House Specials! Our lowest prices ever!
March is here and it will be spring before you know. Now is the time to get your Pony ready for the nice weather. To celebrate our second annual CJ Pony Service Open House on Saturday, March 27th, we are offering our best deals ever on our most popular installations!
$279.95 Installed!
1964-1973 Leaf Spring Replacement
Includes all the components of our leaf spring kits and installation.
$1,849.95 Installed!
1964-1968 Coupe/Fastback Floor Pan Replacement
Includes all of the components of our floor pan kit, installation, sealing and priming.
$1,949.95 Installed!
1969-1970 Coupe/Fastback Floor Pan Replacement
$279.95 Installed!
1964-1970 Welded On Subframe Connectors
Includes subframe connectors, labor, prime and paint.
$2,099.95 Installed!
1964-1966 Painless Wiring Harness
Includes Painless complete chassis wiring harness and installation.
$1,999.95 Installed!
1967-1968 Painless Wiring Harness
$229.95 Installed!
1964-1968 Fuel Tank Kit
Includes fuel tank, fuel sending unit, filler hose, gaskets and labor.
$179.95 Installed!
1964-1973 Pertronix Tune Up Kit
Includes Pertonix ignitor, flame thrower coil, spark plug wires and installation.
$499.95 Installed!
1986-1998 3.73 or 4.10 8.8" Gears
Includes ring and pinion gears, installation kit, Royal Purple synthetic fluid, speedo correction and labor.
$259.95 Installed!
1982-1993 Door Pin Replacement
Get rid of those sagging doors! $259.95 installed for both sides or $129.95 for driver's door only.
$199.95 Installed!
1987-1993 Stock Style Headlight Kit
Includes two standard headlights, two marker lights, two parking lights and labor.
$429.95 Installed!
1982-2004 Standard Carpet Replacement
Includes molded replacement floor carpet and labor.
$269.95 Installed!
1986-2004 Pro 5.0 Shifter
Includes Pro 5.0 manual transmission shifter and installation.
$529.95 Installed!
1986-2000 King Cobra Clutch Kit
Includes clutch, TO bearing, flywheel resurface and labor.
$629.95 Installed!
2001-2004 Spec Stage 1 Clutch Kit
$189.95 Installed!
1982-2004 Adjustable Clutch Cable Kit
Includes clutch cable, firewall adjuster, clutch quadrant and installation.
$279.95 Installed!
1979-2004 CJ Pony Pro Kit or Sport Springs
Includes lowering springs and installation. (Does not fit 1999-2004 Cobra)
$379.95 Installed!
1979-2004 Tubular Upper and Lower Rear Control Arms
Includes two upper control arms, two lower control arms and labor. (Does not fit 1999-2004 Cobra)
$329.95 Installed!
1979-2004 Maximum Motorsports Full Length Subframes
Includes full length subframe connectors, labor, prime and paint.
$589.95 Installed!
1999-2010 3.73 or 4.10 8.8" Gears
Includes ring and pinion gears, installation kit, Royal Purple synthetic fluid, speedo correction box & labor. (Excludes 05-10 Auto Mustangs)
$869.95 Installed!
1999-2010 3.73 or 4.10 8.8" Gears and XCalibrator 3
Includes ring and pinion gears, installation kit, Royal Purple synthetic fluid, SCT XCalibrator 3, custom tune and labor.
$629.95 Installed!
2005-2009 Painted Silverhorse Quarter Window Louvers
Includes a pair of Silverhorse Racing flush-mount quarter window louvers and installation.
$599.95 Installed!
2005-2009 CDC Convertible Styling Bar
Includes Classic Design Concepts convertible styling bar and labor.
$1,149.95 Installed!
2005-2010 Ford Racing Hot Rod Cams
Includes Ford Racing hot rod camshafts and installation.
$329.95 Installed!
2005-2010 Hurst Competition Plus Shifter
Includes Hurst Competition Plus manual shifter and labor.
$299.95 Installed!
2005-2010 Ford Racing "K" Lowering Springs
Includes Ford Racing lowering springs and installation.
$449.95 Installed!
2005-2010 BMR Upper and Lower Rear Control Arms
Includes BMR rear control arm set and labor.
$229.95 Installed!
2005-2010 BMR Adjustable Panhard Bar
Includes BMR panhard bar and installation.
$500 Labor!
2005-2010 Ford Racing Standard Whipple Supercharger Install
CJ Pony Service will install your FRPP standard supercharger kit for only $500. (Price is labor only, does not include supercharger)
$750 Labor!
2005-2010 Ford Racing High Output/Edelbrock Supercharger Install
CJ Pony Service will install your high output or Edelbrock supercharger for only $750. (Price is labor only, does not include supercharger)
