  • Mustang Sound & Shine All
clay bar?
  • Thread starter Thread starter 03redfiregt
  • Start date Start date Mar 4, 2004
03redfiregt
290
Dracut Ma
Mar 4, 2004
  • Mar 4, 2004
Hey guys wich clay bar is best? I have never used one before. I have some light water spots on my car most likely from the water at my house. The sun got on it a couple of time before i could dry it and i can't get the spots out. A few people told me to try using a clay bar but witch one is best?
G
geaux
49
Atlanta GA
Mar 4, 2004
  • Mar 4, 2004
usually claymagic or mothers comes up as good
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Mar 4, 2004
  • Mar 4, 2004
I've had good results with the Zaino claybar and their related products. Check them out @ www.zainostore.com
bigblackboat
43
Langhorne, Pa.
Mar 4, 2004
  • Mar 4, 2004
claymagic
Use the claymagic light grade blue clay bar with automagic 49bodyshine. It's a fantastic combination. Works wonders on your exterior and won't crumble like most other clay bars.
MSM0075
741
Central Jersey
Mar 4, 2004
  • Mar 4, 2004
I've tryed Moters and ClayMagic. Diden't really tell a difference. I heard somewhere that ClayMagic isn't as good beacuse the "lube sucks"
gunsfan
848
Boston (not Austin)
Mar 5, 2004
  • Mar 5, 2004
True, the lube is not great, but you can use any quick detailing spray or even a 10-1 mix of water and car soap to lube...Its the quality of the bar that should matter most, and Claymagic and Mother's for that matter are both good choices.
MSM0075
741
Central Jersey
Mar 5, 2004
  • Mar 5, 2004
gunsfan said:
..even a 10-1 mix of water and car soap to lube...
Whats the best way to do mix? (Ratios)
UMDSmith
226
Salisbury, Maryland
Mar 6, 2004
  • Mar 6, 2004
Actually, after using the clay, they make some fine quality artist sculpting and shaping clay that I believe is the exact same (that California clay). The only difference would be price. The artist stuff is cheaper. I will do some research and see if it really is the same, because the principle of how the clay works is identical.
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
Mustang Sound & Shine All Tuesday at 12:29 PM
NotaVegetarian
N
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
