  • SN95 4.6L Mustang Tech
Cleaning carbon buildup ?
  • Thread starter Thread starter Ferris Bueller
  • Start date Start date Apr 6, 2004
F
Ferris Bueller
21
MD
Apr 6, 2004
  • Apr 6, 2004
I have a PI-headswapped 1998 GT with 80,000 miles on it with a persistent pinging problem. Pinging occurs above 4000 RPMs and while under a load in higher gears (below 2000 RPMs). Pinging only occurs when engine is at operating temperature.
I have already cleaned the MAF sensor, replaced the fuel filter, replaced the spark plugs, and replaced the upstream O2 sensors. The problem isn't as severe as before, but its still pinging enough to bother me.
My question is: Would carbon buildup cause pinging when the cylinder is hot? And if so, what is the best way to clean carbon buildup without taking off the heads?
I frequently drive in traffic and rarely get to rev the engine up and I'm guessing the combination of low RPMs, high compression ratio, and 93 octane fuel mightbe leaving carbon deposits.
Blk03GT
337
Ca
Apr 6, 2004
  • Apr 6, 2004
I suppose it could given enough build up on the pistons. If you had enough build up it could raise the comp.
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
