Cleaning out a gas tank
freddiecougar
50
Now that I have my ignition problem sorted, I have a new dilemma. The car sat for 15+ years before I started on it. I drained the tank, but that wasn;t enough. It is still sending mountains of garbage through the fuel system. What is the best method for cleaning out a gas tank? I am taking it out of the car tomorrow, but I need to know what to do to actually get it clean inside. Anyone have any tips?
Tim
I have a similar situation w/ my 68. It was sitting for an undetermined amount of time when I got it. Upon start-up, the diaphragm of the fuel pump was eroded.
I considered trying to clean out the tank. But, I was able to get an entire new tank kit for under $100. I've yet to install it, as I'm hoping to yank the engine soon--no sense in installing a new tank, put a little gas in, and then let it sit again.
Like you, I couldn't stand sending all that nasty gunk through the fuel system.
I don't know your situation. But, honestly, I'd consider a new tank if you can afford it.
Which of your cars is it for, the '66?
I had no clue that tanks were that cheap....I never would have bothered to post the question if I knew that! I ended up with a 20 gal tank for a 69. It was FREE (from a stalled project belonging to a friend), and I just had to modify the filler neck. Easy solution!
Thanks for the help, everyone.
Tim
I wanted to go with the extra capacity tank like that but was worried it would hang down and show under the valance. Does yours hang down?
A little bit. Not much, and it certainly isn't something that jumps out at you. I will get a picture for you. The biggest difference is in the trunk, the tank is definitely taller. My trunk mat fit differently, and you lose a little depth.
Tim
+25 on the new tank! One for my '73 is gonna cost $179; but it would be worth it to keep cam break-in from being cut short by a big goober of the nasty-smelling cr@p in my tank clogging up the carb.
From what I can see/read; you "pre-71 guys" have it easier in that the mods to re-angle the Mustang filler neck for a Cougar are a lot less extreme than on the big Cats. On the other hand, the last place from which I looked at a gas tank, was selling the 71-2-3 Coog tanks for the same price as the Stang tanks; and the drawings indicated they were definitely NOT the same tank for different vehicles.
As for "upsizing".... I were in your situation; I'd be willing to lose an inch or so of trunk depth if the trade-off was a couple more gallons of fuel!
