Last week I drop the rear end of my 73, Disassembled the springs, pulled the axles. I left the differental and the housing mated. Today I took the housing, springs, perches, drive shaft to be sand blasted. I sealed the axle tube ends with a shop rag and duck tape. The guy doing the job told me I will need to clean out the inside of the housing and gears before I put every thing back to gether. OK. I was intending to pull the differential and replace the gasket and inspect every thing before I painted and reinstall. I realy have two questions, 1 - when I pull the diff will the entire unit (the ring and pinion) come out of the housing as one unit (I thing so, but with this I'm a newbie, never did this before), but either way, 2 - what do I clean the insides with (gears included) to get rid of all the nasty little particals so when I put it back together and fill with gear oil I don't wreck the rear in the first 100 miles?
Thanks
Thanks
I recycle it by mixing mine with used motor oil and use it to burn brush. I chalk it up to my contribution to "Global Warming"
