Cleaning Upper Intake
  • Thread starter Thread starter Cole's 1987 GT
  • Start date Start date Apr 29, 2014
1 of 2 Next Last
C
Cole's 1987 GT
44
Ohio
Apr 29, 2014
  • Apr 29, 2014
I have my upper intake off my 87 to work on some stuff and I sprayed the inside of the upper with carb cleaner and it looks fine but I was wondering if I should take the egr off and clean whatever is behind it or if I should be ok with just leaving it on and cleaning it. Thanks and last time I messed up and put something in the wrong forum so if this is not the right place please let me know where it should be.
C
Cole's 1987 GT
44
Ohio
Apr 29, 2014
  • Apr 29, 2014
Ok im pretty sure I put this in the wrong place sorry
elarm1
1,428
652
154
N.Va
Apr 29, 2014
  • Apr 29, 2014
Since you have it all apart, its a no brainer to clean it.
C
Cole's 1987 GT
44
Ohio
Apr 29, 2014
  • Apr 29, 2014
well the egr is not off its still on the upper but I did not know if it was worth taking it off because I'm not even sure whats behind it to clean?
madspeed
Colonel Mustard
1,332
204
a van down by the river
Apr 29, 2014
  • Apr 29, 2014
If it aint broke dont try to fix it.
Reactions: Audiophile
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
  • Apr 30, 2014
Ok sounds good just thought I should ask and make sure.Thanks
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Apr 30, 2014
  • Apr 30, 2014
no big deal to clean i would....but i guess if it aint broke dont fix it can apply also...
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Apr 30, 2014
  • Apr 30, 2014
It's two bolts. I'd take it off and clean it. Might need a new gasket, that's all.
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
  • Apr 30, 2014
Ok I took it off and cleaned it I have another question is there any reason to take the throttle body off to clean what's behind it or can I clean the upper with it on? Thanks
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Apr 30, 2014
#10
  • Apr 30, 2014
  • #10
It's just a matter of a few bolts and some new gaskets... It's one of those while you're in there kind of things. You have it off and apart you might as well give it the gusto in my opinion.
Reactions: Cole's 1987 GT and 89oem
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Apr 30, 2014
#11
  • Apr 30, 2014
  • #11
you may want to pull your MAF off and spray really well too, that way your whole airway is freshened.... just unplug it and undo the two bolts holding the bracket to the shock tower.....
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
#12
  • Apr 30, 2014
  • #12
Its an 87 so I don't have mass air yet and does anyone know what all gaskets etc. I need for the throttle body and does napa have them I cant seem to find them on there site. Thanks
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Apr 30, 2014
#13
  • Apr 30, 2014
  • #13
duh, should have read that ...
madspeed
Colonel Mustard
1,332
204
Apr 30, 2014
#14
  • Apr 30, 2014
  • #14
Napa should have them
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
#15
  • Apr 30, 2014
  • #15
Ok what gaskets do I need to put the throttle body back on with I found the TBI mounting gasket just not sure what else I need thanks.
madspeed
Colonel Mustard
1,332
204
Apr 30, 2014
#16
  • Apr 30, 2014
  • #16
you need two of those gaskets, one goes in between the throttle body and the egr spacer, the other in between the spacer and throttle body
madspeed
Colonel Mustard
1,332
204
Apr 30, 2014
#17
  • Apr 30, 2014
  • #17
same as you removed
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
#18
  • Apr 30, 2014
  • #18
Ok I thought there would be more than the two thanks for the help!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 30, 2014
#19
  • Apr 30, 2014
  • #19
Bring the upper to a machine shop and for 20 bucks have them hot tank it. You can take the EGR and spray some TB cleaner in the holes and use an old tooth brush. Same for the TB and IAC valve.
C
Cole's 1987 GT
44
Ohio
Apr 30, 2014
#20
  • Apr 30, 2014
  • #20
I got it all cleaned up pretty well Im glad I took the TB off there was gunk caked up pretty good in it I was pretty surprised the car only has around 65k miles or thats what the spedo has on it.Thanks
1 of 2 Next Last
M
Upper intake oxidation
  • MadMatt7
  • Nov 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
