cleaning wires
  • Thread starter Thread starter charlies
  • Start date Start date Oct 9, 2004
charlies
390
in front of computer
Oct 9, 2004
  • Oct 9, 2004
the wires of my under-hood harness are in good shape. they are supple, and somehow, no moron has ever spliced into it. however, the tape is coming unwound in places, and the wires have grease and grime on them in places. it is not overwhelming in quantity, but it is not coming off with soap and warm water. any suggestions? also, any tips for cleaning the plugs?
2nd Mustang
2,488
Southern California
Oct 9, 2004
  • Oct 9, 2004
I use vinyl dressing, like the ones used on tires. I also found this tire cleaner at the 99 cents store that cleans the tire before using the dressing, works well, so maybe could be used on the wires too?
charlies
390
Oct 9, 2004
  • Oct 9, 2004
thanks. do you think vynil dressing would prevent an elect. tape wrap from sticking afterwards?
2nd Mustang
2,488
Southern California
Oct 9, 2004
  • Oct 9, 2004
I'm sure the dressing would prevent anything from sticking. Once electrical tape starts unwrapping, it's effectiveness is gone, best to redo the tape. I remove the tape until I get to a point that the tape is still intact then add new electrical tape. I may be paranoid, but at the starting point, I use a small skinny cable tie to hold the new tape to the old.
charlies
390
Oct 9, 2004
  • Oct 9, 2004
thanks alot for your suggestions. i do, in fact, intent to replace all of the electrical tape. what i meant though, was this:
after i clean the wires with vinyl dressing (i don't know what this is btw), would the residual vinyl dressing on the wires cause problems with the adhesion properties of the new tape wrap?
2nd Mustang
2,488
Southern California
Oct 9, 2004
  • Oct 9, 2004
I guess vinyl dressing wouldn't be a good idea if you're going to replace all the tape. Maybe something like Simple Green might be a better choice to clean with, but it may still leave some residual coating on the wires. You're probably going to have to experiment unless someone else knows of something else. Have you thought of using vinyl tubing made for wiring harnesses? They have a slit down the length of the tubing so you just slip it over the existing wires. I do believe they are available in different diameters.
charlies
390
Oct 9, 2004
  • Oct 9, 2004
that is a good idea. i am planning on cleaning, taping for protection, then the tubing for looks. i have never tried simple green.
bnickel
5,640
lubbock, texas
Oct 9, 2004
  • Oct 9, 2004
plain old GO-JO hand cleaner works better than anything i have ever seen for cleaning wiring
crushnut
870
Oregon
Oct 10, 2004
  • Oct 10, 2004
That stuff is awesome! It has always worked for me.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
  • JRC99
  • Apr 19, 2025
JRC99
J
R
Car shuts off under throttle, idles fine. Looking for some pointers.
  • rmarcotte
  • Jul 8, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Aug 1, 2023
rmarcotte
R
