H humaxxx Member May 2, 2007 35 0 6 Jun 26, 2008 #1 Jun 26, 2008 #1 hello, maby a stupid question.. If my piston has a diameter of 4.440 and the clearance thats needed is 0.0050 what is then the bore size !!!!! 4.445 or 4.460 greets Freek (from Holland)
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Jun 26, 2008 #2 Jun 26, 2008 #2 humaxxx said: hello, maby a stupid question.. If my piston has a diameter of 4.440 and the clearance thats needed is 0.0050 what is then the bore size !!!!! 4.445 or 4.460 greets Freek (from Holland) Click to expand... 4.445, and you want to use a hone to get that .005 clearance. you dont want to bore the engine that size straight away.
H humaxxx Member May 2, 2007 35 0 6 Jun 26, 2008 #3 Jun 26, 2008 #3 OK......a mean 4.445 or 4.450....(don't matter anymore) This clearance is also with the rods 0.002-0.0025 per diameter......0.001 - 0.00125 per side
