  • SN95 4.6L Mustang Tech
clock spring
  • Thread starter Thread starter mustang_gt_jon
  • Start date Start date Jan 17, 2006
M
mustang_gt_jon
  • Jan 17, 2006
can someone tell me what a clock spring does. 96 mustang gt. located in steering column. thanks.
twogts4us
4,188
12
79
Dunedin, FL
Jan 17, 2006
  • Jan 17, 2006
it's part of the air bag system, but not sure exactly what it does, sorry. Here, this may help you a lil bit if you are changing it yourself - http://forums.modulardepot.com/showthread.php?postid=392581
N
n0v8or
604
Rhode Island
Jan 18, 2006
  • Jan 18, 2006
The "clock spring" isn't actually a clock spring, it just looks like the mainspring inside of a mechanical watch. It is a length of flexible printed circuit conductor film wound up in the shape of a spring, and used to route circuits to and from the rotating steering wheel. As you turn the steering wheel, the "spring" becomes larger or smaller in daimeter as it winds/unwinds around the steering column.
The alternative (used in the "old days") is a set of sliding contacts similar to the brushes in your starter motor. These were fine for the horn switch, but not considered relaible enough for air bag power.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jan 18, 2006
  • Jan 18, 2006
itr also hooks up the cruise control circuit
hognutz
1,940
albany, oregon
Jan 18, 2006
  • Jan 18, 2006
my limited understanding is it just aides in making sure the wiring in the column does not bind up.
basically your air bag and crusie.
I had a 2000 durango that had a clockspring recall. the day the recall came in the mail the cruise and stereo controls quite working on the column. I assume the airbad would not have deployed either. I kind of laughed at the timing of it all. open the mail that day and on the way home from the gym the **** quit working.
it was underwaranty though so I did not do the work.
1LowGT
294
st louis mo.
Jan 18, 2006
  • Jan 18, 2006
if you have an accident and the bags deploy you have to replace it 9 out of 10 times cause the current from the bag burns it,my buddy owns a body shop.
D
d90212
253
kailua, hawaii
Jan 19, 2006
  • Jan 19, 2006
clock spring also incorporates the horn circuit.
i question the last sentence in the statement. the power needed to deploy an airbag. ohm out an airbag circuit. please pple, if you dont know what your doing, never circuit test an airbag circuit. that is why we use airbag simulators to decoy airbag components for diagnosis. most airbag circuits are loomed in yellow or have a yellow connector.
like computer networking, its always better to hardwire a system than to have a wireless system, like n0v8or said its more reliable. as in this case to update from a contact switch to a clockspring setup.
now how many amps do you think runs through a multimeter in ohms does it take to deploy an airbag? let me know if you decide to try.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jan 19, 2006
  • Jan 19, 2006
I just replaced the clock spring on my '94 F-150. Not a difficult job at all. Just got to be careful of the air bag assembly, don't want that thing going off in your face.
Bottom line is that ALL steering wheel mounted devices and controls interface via the clock spring. Cruise control, horn, air bag, stereo controls (if you have a set on the steering wheel that is).
The clock spring is a flexible interface between the steering wheel and the steering column.
U.M.
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
Thinking of selling my stang.
  • 2003 mustang gt modded
  • Mar 26, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 26, 2026
Can anyone identify this electrical plug?
  • 93.5.0GT
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2025
Mustang5L5
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
R
For Sale NEW 2026 OEM Rims and tires for sale
  • RSchultz
  • Aug 3, 2026
  • Other Classifieds
Other Classifieds Aug 3, 2026
RSchultz
R
