Closed Loop / Open Loop ?
  • Thread starter Thread starter VB's03WHTGT
  • Start date Start date Aug 13, 2005
V
VB's03WHTGT
NC
Aug 13, 2005
  • Aug 13, 2005
At what coolant temperture does the computer go into closed loop operation and start reading the O2's?
WhiteDevil
2,717
San Diego
Aug 13, 2005
  • Aug 13, 2005
Its after a certain amount of time from when you start the car i believe.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 13, 2005
  • Aug 13, 2005
There are a couple factors. Coolant temp is one of them, in addition to time. I don't have my TwEECer software loaded anymore, so I can't say exactly, but it's pretty low, like 135* or something.
WhiteDevil
2,717
San Diego
Aug 13, 2005
  • Aug 13, 2005
Yeah i dont have mine in front of me either. But it usually takes only a few minutes to reach closed loop on my data logs when driving around.
HISSIN50
34
129
Aug 14, 2005
  • Aug 14, 2005
The puter should go into CL once the O2's light off. This can take 30-120 seconds normally (a nice feature of HEGOS).
Then the fuel is trimmed via the sensory input that Rootus mentioned.
On a fox, one sees full CL, per the ECT, at ~178*F. Not sure on an SN.
This is from articles, books and info I have read about the EEC function, so it might not quite be the same as what guys who stream, tune, etc see.
WhiteDevil
2,717
San Diego
Aug 14, 2005
  • Aug 14, 2005
Hmm thats interesting. Well i know that it only takes a short time for my car to start going into open loop. But on the stock comp when you are first at idle or when you are decelerating(things that bring you out of closed loop) you will not get numbers from the OL_stabalized_fuel until you reach 160 degrees. You will get them from the other table whos name escapes me right now.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 14, 2005
  • Aug 14, 2005
yeah, the ECT doesn't affect the time when it goes into CL. Since our O2's are heated through 12V, they don't need the heat of the exhaust to get hot enough....
I don't know the time, But I believe 120 seconds sounds right. That is about the same time as when the smog pump turns off.
Scott
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
MSPNP2 Closed Loop Initial Values
  • Gibson17
  • Mar 14, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 21, 2025
Gibson17
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
