Hey im new to this forum but i am looking for some friendly advice. I have an 02 GT and a about a month ago a clunk noise started from my front end. It has continued to get worse. Its not a short clunk it occurs for about a half second while the front end is going up or down. The noise only occurs when i go down a driveway, when i apply my brakes hard enough for the front end to dip (especially at low speeds), and when i hit a crack in the road it will sometimes do it. When the clunk/noise occurs i can feel the vibration from it on my feet.
When i bounce on the hood of my car while it is parked the noise does not occur and when i am not moving and i turn the wheel from left to right the noise does not occur so i dont think it is from the steering components. I just replaced the front struts because i thought it might be those and i needed new ones anyway..(96K miles) and i have new wheel bearings.
i removed the tires and nothing seems to be loose and the sway bar mounts are not loose and the nut on the top of the strut tower is tight and torqued correctly. i have no signs of oil leaking anywhere in the front. the car does not vibrate while driving at high speeds. i have stock coil overs and my front end is all stock and the car has never been crashed. thank you all for your advice and time. mike
