Clunking noise from rear when accelerating from a stop
  • Thread starter Thread starter dg28182
  • Start date Start date Jan 31, 2004
dg28182
633
Melbourne, FL
Jan 31, 2004
  • Jan 31, 2004
Pretty much what the topic says.. When I'm at a dead stop or just barely moving, something makes a clunking noise in the rear end of the car. It just about always seems to be 3 clunks, one right after the other.
Anyone have any ideas?
NO_RICE
405
Tucson, AZ
Jan 31, 2004
  • Jan 31, 2004
Could be a bad diff, could be a bad U joint. I would check for play in the u joint first (but with three clunks, its doesn't sound likely), if thats the case get an aluminum drive shaft. If that not the case I would have someone watch to see if both tires spin wheel you dump the clutch. If not, you're probably in for an expensive fix. Maybe that clunking isn't so bad after all
remat457
587
Seattle/Tacoma
Feb 1, 2004
  • Feb 1, 2004
Probably too easy but have you checked to make sure your wheel lugs are tight?
MUSTANGJOE
Silver Stanger
1,644
17
59
Feb 1, 2004
  • Feb 1, 2004
Im sure its just a bad U joint .
marcus95
2,133
California
Feb 1, 2004
  • Feb 1, 2004
Joe is prob. right, U joint. cheap fix. Do this if you can. Jack the rear end of the car up on flat ground with a floor jack, lift rear end from under pumkin. put car in neutral. no e brake, block front wheels. get it high enough so both wheels off ground get someone who can watch where the driveshaft connects to the rear end diff. spin one of the wheels by the tire and see if you can replicate sound. 100 bucks says its your u joints. That is where the prblem is. If not maybe a quad shock mount.
dg28182
633
Melbourne, FL
Feb 1, 2004
  • Feb 1, 2004
Awesome, thanks for the help guys. I hope it's just a U-joint. Those I can pick up at work for cheaper than dirt. ( I work at Advance Auto Parts )
J
jerry beach
2,671
Ocala,FL
Feb 1, 2004
  • Feb 1, 2004
Check to make sure your bolts arent coming loose at the drive shaft flange that mounts to the differential.
I
iluvcars
197
chicago
Feb 1, 2004
  • Feb 1, 2004
what about the torque boxes? they are only spot welded from the factory, could those be coming loose and making the noise?
9
9 Deuce GT
550
Geneva, NY
Feb 2, 2004
  • Feb 2, 2004
Check troque boxes, look for worn bushings in control arms, u joint.
MUSTANGJOE
Silver Stanger
1,644
17
59
Feb 2, 2004
#10
  • Feb 2, 2004
  • #10
This could be the problem aslo...It happened to me!
46defense
445
Sanford Fl.
Feb 2, 2004
#11
  • Feb 2, 2004
  • #11
Mine was doing that at one time and I couldn't figure out what it was for the life of me. Then one day at the strip my buddy noticed on the video he was taking that only one tire was spinning. I replaced the traction-loc unit and never heard the clunking again. I would do what no_rice said and check to see if you are a one wheel wonder or not. Easy thing to check. Good luck! Let us know when you finger it out.
dg28182
633
Melbourne, FL
Feb 3, 2004
#12
  • Feb 3, 2004
  • #12
The best thing I can do right now is make an appointment at the local shop here that we all go to ( 80% of our Mustang club..) and let the owner take a look at it. That's going to cost some cash tho...
I have access to ramps.. just changed my oil this morning. I just don't know what to look for.
46defense
445
Sanford Fl.
Feb 4, 2004
#13
  • Feb 4, 2004
  • #13
Did you even bother to check any of the things we mentioned?
dg28182
633
Melbourne, FL
Feb 4, 2004
#14
  • Feb 4, 2004
  • #14
Not yet. Haven't had the time. It's hard to get under my car even with ramps, it's pretty low.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
