  • SN95 4.6L Mustang Tech
Clunking when i shift
  • Thread starter Thread starter iancgt97
  • Start date Start date Nov 3, 2008
I
iancgt97
East Haven, CT
Nov 3, 2008
  • Nov 3, 2008
This mysterious clunking.... Every time I shift gears, doesn't matter which gear or how fast I'm going I hear a sick clunk from my rear end area. I just replaced my tranny fluid, and I had no metal flecks or anything to tell me something was wrong with it. I replaced my rear pinion seal, and although I had lost alot of fluid there didn't seem to be anything wrong with it. I go to school for auto tech, I can't figure it out, and neither can my instructors. Wtf is going on? must be rear differential right??? It's a 97 GT. Please help me it's driving me nuts. Another symptom is me having to wrestle to get into gear sometimes, and i see no clutch or tranny problems. This might just be the way mustangs are though.
I
iancgt97
East Haven, CT
Nov 3, 2008
  • Nov 3, 2008
seriously
I don't mean some little noise either. It sounds crazy. If i don't have my radio all the way up it sounds like im gonna lose my rear axle or something. Has anyone had this problem besides me?
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 3, 2008
  • Nov 3, 2008
How many miles are on it? Does it have a different rear gear in it?
I
iancgt97
East Haven, CT
Nov 4, 2008
  • Nov 4, 2008
stock
stock gears 90000 miles
AdRock
521
South Texas
Nov 4, 2008
  • Nov 4, 2008
Was the noise there before you changed the pinion seal? If not, I would suspect that the pinion crush washer may have crushed quite a bit more when you tightened the pinion nut. This would completely jack the backlash that the rear gear should see. This could easily cause a loud clunk since there would be so much play in the gears.
Also check your U joints. A joint going out will cause banging noises. It will also usually cause a vibration at highway speeds.
Check all the rear control arm bushings. If one or more has deteriorated and come out thenit will allow the rear end to move around to much.
Check those things and see what you find.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
