  • SN95 4.6L Mustang Tech
Clutch adjustment
  • Thread starter Thread starter Ls?lol
  • Start date Start date Sep 19, 2019
L
Ls?lol
Kennett
Sep 19, 2019
  • Sep 19, 2019
My 03 mustang gt clutch does t catch until I left almost all the way out of the pedal. I’ve have a new stage three clutch, new adjustable clutch cable, and aftermarket quadrant. I have it adjusted all the way out and it catches where it Suppose to but I have a lot of free movement in my pedal now. Is there any thing I can do different to help this.
08GT500
5 Year Member
Jul 12, 2018
918
140
63
Massachusetts
Sep 21, 2019
  • Sep 21, 2019
Hi,
I’d re-check the new cable/adjuster/quadrant parts.You have a firewall mount Cable adjuster, not adjustable Cable- correct?
Check the kits fitment info.in instructions. Steeda & others sell Cable/quadrant/Firewall adjuster kits loosely advertised as “82-04’ Mustang fitment”, but fit 1982-95 5.0’s or 1994-04 Mustang 3.8’s. Not 96’-04’ 4.6L’s.
If all is well, there- check these:
1) Some quadrants have (2) spots for the Cable to attach, verify you’re in the right one.
2) Verify Bellhousing’s seated to Block tightly, and isn’t moving when Clutch is depressed (Bolts bottoming out before clamping).
3) From the pedal to the Fork, verify no cable attachment points are moving under the additional load created by the new Clutch when the pedal’s being cycled.
Hope that helps..
Good luck!
- Keeping in mind it’s not broken-in, yet.
Does the Clutch engagement (Pedal height) seem to vary greatly while driving during stops & starts, any noises or excessive slippage occur?
-John
L
Ls?lol
Kennett
Sep 21, 2019
  • Sep 21, 2019
08GT500 said:
Hi,
Hope that helps..
Good luck!
-John
The only noise I got is when I let out of the clutch when it’s in neutral.
08GT500
5 Year Member
Jul 12, 2018
918
140
63
Massachusetts
Sep 21, 2019
  • Sep 21, 2019
Hi, likely the throwout bearing touching the Pressure plate fingers, adjustment a tad tight, we’ll address that. Rest sounds good if that’s the only issue, aside from the pedal..
You mentioned adjustable Cable & Quadrant...but not the Firewall mount adjuster. It’s required with your setup & you didn’t mention that you had one....
If you don’t, that’s likely your issue. I can give you a P/N# if desired..
If you DO have the Adjustable Cable/ Quadrant/Firewall mount adjuster.. I’ll verify.. ..You’ve adjusted the Cable fully in at the Clutch fork, the firewall adjuster out to maximum & the clutch now grabs & releases at the pedal height you want, but you’re pedal doesn’t spring back up & sit solid at normal height when released, is that accurate?
Any finds running down the list thus far?
-John
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Stage 3 clutch rattle
  • stage3
  • May 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
