  • 1994 - 1995 Specific Tech
Clutch and Flywheel
  • Thread starter Thread starter Guero
  • Start date Start date Feb 5, 2007
Guero
2,148
Feb 5, 2007
  • Feb 5, 2007
Well i decided to get the king cobra clutch with supposably 10% less pedal effort. And a stock flywheel. im getting these from ddperformance.com. Anything else i should order so i dont have reorder stuff
parchisi
519
New Mexico
Feb 5, 2007
  • Feb 5, 2007
probably a throwout bearing and a pilot bearing would be good to replace also. while you're messing around under there, an adjustable cable and a firewall adjuster would be good to do.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 5, 2007
  • Feb 5, 2007
the clutch should come with a throwout bearing. you may want to add a new bearing retainer to the list as well depending on how yours looks.
The Hitman
2,541
Orlando, FL
Feb 5, 2007
  • Feb 5, 2007
For some reason I feel as though my King Cobra didn't come with a throwout bearing but came with instructions as to which one you need to buy (It'll give you the part num) to go with it. It's been a few years though.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 5, 2007
  • Feb 5, 2007
My King Cobra clutch did in fact come with a TOB, so you'll probably just want to add a pilot bearing and maybe a bearing retainer as mentioned before. Also, take the time to inspect the pivot ball on your bellhousing since they do have a tendency to wear over time, especially if you've been using a fairly stiff clutch.
The Hitman
2,541
Orlando, FL
Feb 5, 2007
  • Feb 5, 2007
Maybe it's the pilot bearing I'm thinking of. My bad.
Guero
2,148
Feb 5, 2007
  • Feb 5, 2007
thanks guys
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
