Clutch bolt size
sj9ers
71
I'm going to be putting a t5 and clutch back in my car but I lost the bolts that attach the clutch to the flywheel. Does anyone know what size they are so i can pick some up.
Thanks
Yes, def use new bolts
M-6397-A302 are nw bolts and dowel pins. The kit is $12 or so.
Any of the rotational bolts (flywheel, clutch and driveshaft) bolts should not be reused. Toss em in the trash and buy new
If you get the kit you'll have to go to summit and order it.
If you go to Ford they will sell them under the Ford parts system (and not ford racing) and they will be maybe $3 per bolt.
See if any local speed shops near you can get Ford Racing parts.
You could go with hardware store bolts but you would need grade 8 or 10.9 bolts and finding the correct one will be tough.
I could check the hardware store and just wait and order it if I can't find it. Do you or does anyone else know what thread size and the length of the bolts are?
Thanks
Dude, generic hardware store bolts are crap, even in higher grades.
The correct bolts have the correct shoulders too. You don't want to have a clutch go into orbit.
I got my kit from Summit.
If needing another source, I'd at least try a parts store for aftermarket bolts made for the application.
Good luck.
