Clutch Bolts
69Rcode_Mach1
1,473
Salt Lake City, Utah
Hey guys I am going to be dropping in my engine and tranny this weekend. Problem is I need the bolts that mount the pressure plate to the flywheel. I went to ford for them. I was told I need 6, but unfortunately they each cost $7.50. Is there any cheaper alternative that you guys recommend. I don't want to pay $50 for a bolt and nut. That is ridiculous.
if you've got an early flywheel, 5/16"x1" NC grade 8 or 9's are what you want. These are available at the chain home improvement stores and many other places locally. The ones for the later 5.0 flywheels are the same length but are 8mm, I don't know the thread count, but it's close to NC in std threads
Man, I saw pics of the aftermath of a clutch explosion. There was a huge hole in the floor board and it went up thru the cowl, lucky the lady racing didn't get her feet cut clean off as it went up instead of sideways. $50 is cheaper than learning to walk with no feet.
