Clutch Cable broke again
  • Thread starter Thread starter twinsnakes23
  • Start date Start date Oct 2, 2007
T
twinsnakes23
23
  • Oct 2, 2007
I just broke my second clutch cable on my 90 GT. My first one was a BBK with quadrant, the second was a Ford Racing one with the same BBK quadrant. They keep breaking near the quadrant end. Is there a better longer lasting cable or am I doing something wrong.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Oct 2, 2007
  • Oct 2, 2007
OEM Ford "universal" cable + firewall adjuster + quality aluminum quadrant =
I take it you've been using the adjustable cables...? Do a search on here and you'll see about a bajillion people having had the same experiences with those things breaking, as well as the non-adjustable OEM-replacement aftermarket cables. I don't normally pimp on name-brand stuff, but in this case, it's warranted.
The "universal" Ford cable is available through places like Maximum Motorsports for about $75 shipped.
T
twinsnakes23
23
  • Oct 2, 2007
I've been reading about the OEM Ford cable, should I keep my BBK aluminum quadrant or get a new one? Also do I need a firewall adjuster or can I do without it?
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Oct 2, 2007
  • Oct 2, 2007
If you're going back to a stock non-adjustable cable, you will NEED a firewall adjuster to take up the slack. Most likely, you'll be able to use your BBK quadrant without any problems, especially if it's a multi-hook type. Some aftermarket quads were made a bit too big because they were designed only to be used with an adjustable cable, so the Ford cable may or may not be long enough to go over the end of it - not sure if there's a way you can take out your quad and measure it to be sure, or not.
If in doubt, you could always just order the firewall adjuster and quad together as a combo for pretty cheap. UPR has a nice setup available (cable not included), and I think MM has a combo deal, as well (with a new Ford cable, I think). I got my FWA and quad back in '05 for something like $40, together, during a sale they had going on.
Also note that, when using a Ford cable with a firewall adjuster, you'll need to pull off that rubber firewall grommet (the FWA takes its place) and trim off the four little nubs that once served to hold the rubber grommet in place onto the cable sheath so that you can poke it into the FWA. You'll also need to transfer the bracket from your previous cable (the one that holds the cable away from your exhaust headers) onto the new Ford cable, but that's easily done. Really minor stuff, you'll figure it out easily once you mock up the pieces onto the car.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
