clutch cable install
  • Thread starter Thread starter Tranceformer
  • Start date Start date Oct 24, 2004
T
Tranceformer
20
  • Oct 24, 2004
I finally bought an oem non-adjustable clutch cable and the retaining clip (c-clip) for my T-5. Not sure how to install it on the fork side of the cable. Is there anything to hold the cable onto the fork? Where does the c-clip attach to?
Rick 91GT
Mustang Master
95
99
PA
Oct 24, 2004
  • Oct 24, 2004
You install the c-clip right after you slide the cable through the hole in the bellhousing, it clips onto the groove in the nylon on the cable, this holds it in place. The end of the cable goes into the slot on the clutch fork, you will need to pry the clutch fork back to get the cable end in the fork.
Pressure/Tension holds the cable on the fork
04sleeper
2,674
14
89
Dallas, TX
Oct 24, 2004
  • Oct 24, 2004
Exactly!
T
Tranceformer
20
  • Oct 25, 2004
I just replaced the clutch cable with an oem non-adjustable one and WHOA!!! No more sloppy play with the clutch pedal anymore. And my trans shifts like butter now that the clutch is disengaging completely now. Only problem is that the clutch engages a bit higher than i'd like and the firewall adjuster is all the way to the firewall. maybe give it some time to settle? other than that its awesome.
V
v8only
2,378
22
49
Oct 25, 2004
  • Oct 25, 2004
you;ll be waiting a couple hundred thousand miles for it to settle and for that cable tostretch. it's probably the quadrant. what type of quadrant are you using??
T
Tranceformer
20
  • Oct 25, 2004
you're probably right, i have the quick-release single-hook from 50resto.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Oct 25, 2004
  • Oct 25, 2004
My clutch cable is aftermarket and horrible. Every stock clutch cabled car I drive is 10 times better. The stockers seem to release really high in the throw, and really easily. Mine releases really low (no matter how I adjust it) and it is mushy, and doesnt release quick. It takes about 1/3 of the throw to release while the sockers all take about 1/5 of the throw, for comparison. Should I get a stock replacement cable?
T
Tranceformer
20
  • Oct 25, 2004
YES
heres where i bought mine
http://buyfordracing.com/Shop_Cart/shopexd.asp?id=168
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
  • Oct 25, 2004
Yeah I have an OEM clutch cable on my car (very nice) and bought it from www.buyfordracing.com for $40 bucks and it comes with a new clutch fork...both are on my car currently...
My clutch grabs to high for me right now but it works...my clutch pedal vibrates right now everynow and then...so I just ordered a clutch pedal bushing (don't know nothing about installing it)...hoping it will help out...?
HISSIN50
34
129
Oct 25, 2004
#10
  • Oct 25, 2004
  • #10
are you sure your clutch is engaging all the way? a semi engaged (or dragging) clutch can vibrate or pulsate under your foot.
good luck with it all.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 26, 2004
#11
  • Oct 26, 2004
  • #11
Well alls I know is the farther I move the clutch pedal grab up (counterclockwise'ing the firewall adjuster) the less the pedal vibrates and most of the time it doesn't now...?
It is definatly disengaging all the way (well above 1inch off the floor before it starts to move)...
How hard is it to put that little clutch pedal bushing on?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
