Clutch cable question...
  • Thread starter Thread starter BlooDReigN
  • Start date Start date Oct 28, 2006
BlooDReigN
283
Calgary, Alberta
Oct 28, 2006
  • Oct 28, 2006
Hey guys...I did a search and didn't come up with anything, so I figured I would make a post about it. I plan on swapping my pedal assembly etc today in the stang. Going from an auto to a standard. Anyway, I need to go grab a pedal assembly from the junkyard and I was wondering if the 4 cylinder clutch cable is the same as the v8 or, or at least close enough to use for my swap. The car has a TKO 600 transmission w/spec stage 3 clutch.
Any advice would be much appreciated
M
MatthewP
355
Calgary, Alberta
Oct 28, 2006
  • Oct 28, 2006
You will need a V8 clutch cable. The rest of it is OK from the 4 cyl. You can get a V8 cable at any speed shop.
-Matthew
BlooDReigN
283
Calgary, Alberta
Oct 29, 2006
  • Oct 29, 2006
Thanks Matt.
nitrous_bob
45
st clair shores MI
Oct 29, 2006
  • Oct 29, 2006
don't use the stocker, specially w/ a heavy clutch.
you'll break the plastic quadrant, at least get the summit adj cable w/ qudrant it's less than $80 i think.
i smoked a motorsport HD in less than a week from using the stock quadrant
BlooDReigN
283
Calgary, Alberta
Oct 29, 2006
  • Oct 29, 2006
Well I'm putting a new quadrant in the car, but I have read adjustable cables like to break. So i'll just get a good quadrant and a firewall adjuster.
M
MatthewP
355
Calgary, Alberta
Oct 30, 2006
  • Oct 30, 2006
I've never had an adjustable cable break. I always use McLeod in the clutch system though - cable, quadrant, firewall adjuster, fork, bellhousing, flywheel, disc, and pressure plate.
-Matthew
stangjunkie
381
  • Oct 30, 2006
i have the summit one and its worked fine for me...
i have never heard that aftermarket ones are likely to break but it is common knowledge that stockers suck
C
Carb'dCobra
26
Tampa, Fl
Oct 30, 2006
  • Oct 30, 2006
BlooDReigN said:
...but I have read adjustable cables like to break...
Not really. I've had the same adj. cable quadrant in my car since 04', never had any problems.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
new to the page I have a TKO vs T56 question.
  • ninefoursix
  • Wednesday at 12:47 PM
  • The Welcome Wagon
The Welcome Wagon Thursday at 2:16 PM
ninefoursix
N
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
