Clutch cable routing
BDAWK2002
139
Old Bridge N.J.
Can anyone tell me how the clutch cable routes. I have tried numerous different way and cant find the two holes where the bracket is supposed to bolt to :( I'm doing a 5 spd swap so I'm not even sure if the holes are even drilled out already.....If someone could post some pics that would be a big help....Plus anyone who has done the swap before please let me know if the holes are already drilled out.....Thank's
95_5.0_stang said:
Wow, I'm in need of this same exact question. I did the v8/5speed swap so I need to know where to drill the hole and how to route the cable. If someone posts pics I will love you forever. :D
I think I found the holes on the fender support.It's right below where the brake lines run from the master cyl.
the hole is right where bdawk said and it is predrilled and threaded. as for the cable routing, it goes between the kmember and motor mount and from there into the clutch fork. during my swap, i took a ton of pics of everything. you can refer here for all of them.....maybe some of them could be useful. if you have any questions, also feel free to hit me up.
http://ridewithdrc.com/roger/mustang/
Thanks for the info....I got the cable routed.Do you what size bolt holds the clutch bracket?And would you happen to know what size bolt holds the dust cover for the clutch fork?Thanks again for the help.
