Anyone have good pics of the route the clutch cables takes down to the bellhousing? I'm installing mine and since it was an AOD car i am not sure how it should route
DO i pass it through the k-member where the steering shaft is? Or does it go somewhere else? Pics please?
Also, when i hook the cable on, i understand there will be tension right? I'll need to use a prybar to hook it up? Should there always be pressure on the pressure plate then?
What happened? It rolled off the jack?
