Clutch Chatter???
I put in a king cobra clutch roughly 1200 miles ago, after my stock throwout bearing took a crap. I broke it in corectly for 500 miles. Nothing started untill 800-1000 miles on it. Now when I take off slowly i feel a small vibration, and just this week it started when I crank the car, I can feel a very small something under the car. fells like something wobbleing. It doesnt seem too bad, barely noticable. But it bothers me not knowing what it is. BTW I cheked my flywheel for hot spots and it looked really good so I didnt get it resurfaced. Anyone know what my problem is?
new pilot bearing
should always cut the flywheel,also did you replace pilot bearing??is the output shaft bearing of the trans good??? and last make sure the clutch fingers are not bent or broke ,could be slapping the throwout bearing
I replaced the pilot bearing. dont think i did the output bearing.? Clutch fingers all looked good when it went in. :shrug:
take it back out
maybe it would be good to redo it ugh.....i know but cut the flywheel make sure the output shaft bearing is good and also make sure the fork and throw out bearing is not bent and seated correctly,also put another pilot bearing in it .good luck dude,just do it youll feel better.i had lots of probs like that and the probs i listed were usually the cause again good luck!!!
