So my stang isnt running right. When it is in neutral, the idle speed goes up and down about every 10 seconds. When I put it in gear the car jerks REALLY badly. Before it would do this every so often. It usually worked when I took my foot all the way off the cutch. So could it have something to do with the clutch elecrical stuff? I looked under near the clutch and there is this plastic thing with a plastic rod that goes in and out when you press the clutch. There are two connectors comming out of it. One I know goes to the ignition as the safety thing but what does the other one do?
Im not even sure it is the clutch though. What else could it be? It was running fine the other day.
