  • 1994 - 1995 Specific Tech
Clutch/flywheel combo
  • Thread starter Thread starter a-spec FD
  • Start date Start date Sep 20, 2006
A
a-spec FD
12
  • Sep 20, 2006
for a 5-speed 95 5.0 vert. whats a good clutch/flywheel combo. I was looking at a ram clutch and a ram aluminum flywheel. I was looking at these:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RAM-88794HD&N=700+0&autoview=sku
http://store.summitracing.com/partd...924755+4294925134+4294862434+115&autoview=sku
What do you guys run, whats good?
badstang123
397
Santa Clarita, CA
Sep 21, 2006
  • Sep 21, 2006
It might be more expensive then what you were looking at...but I went with Mcleod and have been extremely happy.
Killercanary
The car that set the bar.
Altoona, PA
Sep 21, 2006
  • Sep 21, 2006
Your question can not be truely answered without knowing what transmission you run, how much power you make, do you drag race it on sticky tires, etc. There are a number of different clutches out there, but that doesn't mean that they are right for you. I wouldn't put a McCloud twin disc on a stock car, nor would I put a FMS HD in a 600rwhp one. Clutches should be purchased to work with the combo you have. What all do you have done?
94-302-vert
1,947
NE CT
Sep 21, 2006
  • Sep 21, 2006
I'm with Killer...
My car is basically stock and I went with the ford king cobra with a factory replacement flywheel... it will be stock for a while so I am not worried about the power.
I actually wish I had a heavier pedal and it was grabbier... but it holds the power great...
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 21, 2006
  • Sep 21, 2006
Im going to have a 28oz fidanza aluminum flywheel for sale very soon. The weights are removable if your assembly isn't 28oz. You would just need to buy w/e weight you need. It will be for sale for a LOT less than $399 unlike that ram. It has 3k miles on it. I'm going automatic otherwise it would stay. Its a killer piece.
Mike
A
a-spec FD
12
  • Sep 21, 2006
I'm going to use the car as a daily driver, but with a few parts (ie. 355 gears, intake, full exhaust). I hope to put a kenne bell in it down the line. I had a centerforce clutch in my old 95 5.0 and it was good, but expensive. So thats what I'm using the car for a prefomance daily driver.
94-302-vert
1,947
NE CT
Sep 22, 2006
  • Sep 22, 2006
How far away is the KB?
You have to decide if you want a clutch that will hold that now or if you would rather have a clutch that is cheaper and adequate for your combo right now...
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
