clutch help
  • Thread starter Thread starter project 87 5.0
  • Start date Start date Sep 5, 2010
P
project 87 5.0
32
sanford, florida
Sep 5, 2010
  • Sep 5, 2010
i had to put a new clutch in, so i put a new pilot bearing and throwout in too. now when cable is adjusted pedal is great, but now i have a chirping noise when pedal is completly out. When i touch the pedal it goes away. I should have mentioned its all stock kit. thanks
HISSIN50
34
129
Sep 5, 2010
  • Sep 5, 2010
TOB noise.
P
project 87 5.0
32
sanford, florida
Sep 6, 2010
  • Sep 6, 2010
thats not normal is it? When the cable has slack in it thats when i get noise. is there suppose to be a preload on it?
HISSIN50
34
129
Sep 6, 2010
  • Sep 6, 2010
It's not normal but very common. It's a TOB/TOB lubrication issue. Until the TOB can be replaced, you can preload the cable a smidge if the noise is bothersome.
If you just had this clutch installed and/or it's under warranty, the shop should be taking care of it.
P
project 87 5.0
32
sanford, florida
Sep 6, 2010
  • Sep 6, 2010
ok, thanks for the advise. i will be taking it back to them now.
90limited
276
Port Charlotte FL
Sep 7, 2010
  • Sep 7, 2010
My TOB has been chirping for about 25k miles... Used to bother me, but now with the new exhaust not so much of an issue ..... My 88 GT did the same thing for over 70k miles and never gave me a problem.
HISSIN50
34
129
Sep 7, 2010
  • Sep 7, 2010
They can hold up quite a long time while chirping, while some fall apart rather quickly. When it comes to dispensing advice to strangers, I try to error on the side of caution.
And if the repair and parts are under warranty, it's a no brainer.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
