  • 2005 - 2009 Specific Tech
Clutch issues?
  • Thread starter Thread starter slvrpny00
  • Start date Start date Jun 13, 2005
slvrpny00
102
Westland, MI
Jun 13, 2005
  • Jun 13, 2005
A couple of wierd things happened yesterday to me. Everytime I would push in the clutch my radio would cut off and when I let go it would come right back on. This happened a few times until I cut the radio off fearing more problems. On top of that when I reached my destination I pushed in the clutch to put the car into gear as I was taking the key out of the ignition, and the car tried to turn over like I was starting it, and it happened again when I got back home. I let the car sit for a few hours and took it out for another spin in which the car acted fine.
No mods yet.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 13, 2005
  • Jun 13, 2005
i would take it in for warranty as soon as possible. never know what those wires will do, i know there are fuses for that stuff, but i wouldnt want to risk it. also if it is enaging the starter, that is risking some pretty good damage. imagine going down the road at 85 and all of a sudden your starter kicks in....say good by to your starter and probably your flywheel as well...were you completely stopped when the car was acting like it wanted to start? some cars you can push start and if you were rolling, this might be the case. i thought that newer cars were made so you could not push start them...?!?
slvrpny00
102
Westland, MI
Jun 13, 2005
  • Jun 13, 2005
I dropped it off this morning and they had no idea what is going on so I'll post when I find out what is up.
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Mindseye007
  • Aug 16, 2026
Mindseye007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
