clutch linkage mounting ?.
stihl-066
90
Got the new frame rails put in my 69 mach 1. But the only problem is that I realized that it does not have the holes for the clutch linkage in the frame rail. Does anyone have any measurements that will help me out. How should I mount it. Drill some holes and weld in nuts or what. I remember it going under the steering box some what. I do not have the old parts to measure it. Pictures or measurements would be really appreciated.
Bell crank bar is perpendicular to the centerline of the engine
Sorry, don't have measurements for you, but that should get you in the right spot. Also, I'd try nut-zerts before welding in nuts. The heat will take away the temper, and vibration will loosen bolts overtime.
If nothing else, maybe this will get you a bump and someone with a '69 can get you dialed in.
Good luck,
Scott
