  • SN95 4.6L Mustang Tech
Clutch noise?
  • Thread starter Thread starter TheTumbler
  • Start date Start date Apr 4, 2011
T
TheTumbler
  • Apr 4, 2011
I installed a spec stage 2 clutch in my 99 GT. Now there is a noise coming from the transmission. If you press the clutch pedal in about an 1" or 2 the noise stops. besides the noise it seems to be working great, just very annoying. Anyone know what might be from? Someone told me that I perhaps got a bad throw out bearing??
evolucion311
236
Apr 4, 2011
  • Apr 4, 2011
did you install an adjustable quadrant? did you install a new throwout and pilot bearing when you did the job? it's good insurance to always swap them out in addition to replacing the rear main seal whenever you do work on the clutch
trinity_gt
3,125
81
99
Canada
Apr 4, 2011
  • Apr 4, 2011
Release bearings are most heavily loaded when the clutch pedal is depressed (pressed down). This is when they will usually make the most noise if they are bad.
What is the nature of the sound you're hearing? A chirp? A whine? Ticking?
How much free play is in the pedal?
Were all the necessary points (the release arm fulcrum, the sleeve over the input shaft etc) lubed properly before reassembly?
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Apr 4, 2011
  • Apr 4, 2011
Noise? You have to be more specific. My car's transmission was making noise from the bell housing, like a rattling noise, turns out my input-shat bearing was about to go. T-45 is just a terrible transmission, tough, but operates like it was made for a tractor.
T
TheTumbler
  • Apr 5, 2011
I did not install an adjustable quadrant, but I did install a new pilot and throwout bearing. The noise that it makes is more of a ticking noise. I wouln't really say that it has any play in it. Everything seems tight. Seemed when I installed it that everything should have been well lubricated.
trinity_gt
3,125
81
99
Canada
Apr 5, 2011
  • Apr 5, 2011
The noise you're hearing may be caused by the release bearing riding lightly on the spring fingers of the clutch cover. There's going to be a bit of runout there.
Try this: Get under the car with it idling (use jackstands or a hoist ... all due care etc etc). Pull the release arm gently toward the rear of the car to try to pull the release bearing away from the spring fingers. Does the noise go away? (This may be hard if there's no play in the pedal and no "give" in the cable...)
You say there's no play in the pedal. This could be causing the release bearing to ride the spring lightly. You may need to adjust the pedal to give 1/2" of freeplay or so. The mechanism is supposed to be self-adjusting but you can help it by lifting the clutch pedal up and then releasing it. If you still have no play you may need to access the clutch quadrant under the dash and manipulate it to "unlock" it, then adjust it by lifting the pedal.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Apr 5, 2011
  • Apr 5, 2011
Yep.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
