  • 1994 - 1995 Specific Tech
Clutch Problem
  • Thread starter Thread starter 95strokerPSU
  • Start date Start date Jan 21, 2006
95strokerPSU
986
Sacramento from Philly
Jan 21, 2006
  • Jan 21, 2006
A couple weeks ago my clutch felt like it was slipping and I thought I could have just overtightened the clutch cable, not allowing the clutch to fully engage. Now I loosened the cable and the point of engagement is all the way at the top of the pedal, right before I take my foot off, and it's slipping even worse. Am I an idiot and not thinking of something, or could my clutch be dead after 5000 miles.
Its the FMS HD clutch holding 300 RWHP and 350ft/lb.
Thanks
Dave
HISSIN50
34
129
Jan 21, 2006
  • Jan 21, 2006
Dave, having the point of engagement right at the top means that you will slip. That means that in order to have such short pedal travel, you have preloaded the cable a good bit.
To ensure that you are not slipping, you want the pedal to engage right off the floor (for testing purposes at least - not ideal for actual driving). You should be able to feel a hair of slack in the cable with the POE down near the floor. Slack in the cable = no preload = no slipping caused by the cable.
When you referenced loosening: loosening a FWA will make the clutch cable tighter. Tightening the FWA makes the cable looser. Could that have been a point of issue?
Good luck.
BDAWK2002
139
Old Bridge N.J.
Jan 21, 2006
  • Jan 21, 2006
Same clutch same problem.I'm taking mine apart now to see whats up.
95strokerPSU
986
Jan 21, 2006
  • Jan 21, 2006
Good luck.
Thanks for the response
So let me get this straight, you would assume that my clutch cable is still too tight, hence why my clutch engages at the very end when I'm bringing the clutch pedal back out. So by loosening the clutch cable more, it will bring the point of clutch engagement closer to the floor?
HISSIN50
34
129
Jan 21, 2006
  • Jan 21, 2006
Yep. For someone with clutch slippage, one wants to get the point of engagement closer to the floor (so you remove excessive preload on the TOB and PP diaphram fingers, which can cause slipping).
By having the Point of engagement at the top, you have possibly preloaded the diaphram fingers, which is comparable to riding the clutch.
Now if you have an adjustable cable, you actually loosen the nut at the fork. But if you have a FWA, to 'loosen' the cable, you tighten the firewall adjuster.
FWIW, I have a HD kit and have been farting around with the adjustment (my new single hook quadrant does not allow near the fork travel that my old SVO single hook did) and I can have the clutch adjusted so it engages pretty near the top, but with no slippage. So there still might be a clutch (hard part) issue, but dialing all the preload out of the cable is the first thing to do, in case that is the only issue.
My two cents.
Good luck.
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
Clutch pedal too far away
  • 90sickfox
  • Feb 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2025
V
Drivetrain Clutch Cable too Short?!
  • vpap1
  • May 9, 2023
3K
Fox 5.0 Mustang Tech May 23, 2023
vpap1
V
