Clutch problems
  • Thread starter Thread starter mob
  • Start date Start date May 27, 2008
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
May 27, 2008
  • May 27, 2008
Alright so started like a month ago, but it was realll hard to shift into gear. It would barely shift, it just would not want to go into the gear and id have to push the clutch in soooo far, all the way to the end. So I tried turning the fire wall adjuster to the right making it tighter. I went and tried the clutch, and it got worse, it wouldn't shift into first no matter how hard I tried and it would grind all the other gears. So I turned it the other way loosening it up. It worked perfect, my clutch was like a dream, I only had to push it like half way down and it would go into the gear so easily. Then about a week later it got back to how it was before. Extremely hard to put in gear and grinding gears. So now I loosened it up a little more, and its loosened all the way till it wont turn anymore. But it still barely goes into gear, to get it into any gear I have to extend my leg all the way and even then have to push farther for it to go into gear, I have to put the clutch all the way to the wall and push as hard as I can. And even then itll will grind real bad sometimes, and its realll hard to put into gear right when I get past neutral to go into the next gear its like it stops and I have to push so hard to pop it into the next gear. What the hell is going on, I can barely drive my car like this.
A few months ago I was driving my car and my clutch cable just randomly snapped, not sure if this is something similar or has something to do with my clutch cable. I have a King Cobra clutch I put in about 3 years ago, and a Maximum Motorsports FWA and quadrant. Help
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 28, 2008
  • May 28, 2008
I was going to say It sounds like your clutch cable was stretching and the fact that it snapped almost proves it. Get a good clutch cable and you should be fine.
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
May 28, 2008
  • May 28, 2008
K thanks, I guess ill get a new one. How hard are they to put in? And where my clutch cable connects to my firewall adjuster is loose, is that bad?
stickman5.0
11
Anchorage, Ak
May 29, 2008
  • May 29, 2008
Try that cable or the adjuster unit first. If it still does it after that. The tabs on your shift forks may be worn down, or your synrcos are starting to go. But the fact the when you tweaked that tension on the cable would lead me to believe its cable/adjuster issue.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
