I am getting my clutch replaced tommorow, i am going with the king cobra clutch assembly. Now, do you reccomend getting the flywheel machined or get a new one, if so which. also what about an ajustable clutch quadrant?
My95.0L said:May want to look into getting an alum. one while you're at it.
I understand what you're getting at (personally I'm still running my stock flywheel), but in theory, an aluminum flywheel would allow your engine to rev faster as there would be less of an inertial load on the crank when you're trying to spin it. There *should* be a benefit to all engines.Striped5.0 said:how come?![]()
I dont see the possible advantage of having an alum flywheel unless your building a stout engine, other then that it seems like a waste of money when you can just resurface it for under $40
illwood said:I understand what you're getting at (personally I'm still running my stock flywheel), but in theory, an aluminum flywheel would allow your engine to rev faster as there would be less of an inertial load on the crank when you're trying to spin it. There *should* be a benefit to all engines.
That is a damn good question. It would be nice to see some sort of data (timeslips or something) with the same driver, same driveline, running a steel vs. an aluminum flywheel.Striped5.0 said:the question is if the benefit of the alum flywheel on a not heavly modded engine out weighs the cost of the flywheel?
i wouldnt resurface it unless theres some burn marks on there. if its still pretty clean just scuff it with some steel wool or fine grit sandpaperDARK-5.0 said:Heres my question. Is it neccessary to resurface my flywheel when I had it resurfaced maybe 1000 miles ago. I torn my engine back down and took the clutch and flywheel off. I plan resurfacing it, but this would be the 2nd time resurfacing it. Am I safe with the thickness. What are the specs for it.
Jeremy
