Clutch Saftey Switch?
Ok there are 2 switches. I know one is clutch saftey switch and one is cruise controll which is which. the big one with 2 harness's i imagine is the cruise controll. So I am guessing the little one above the gas pedal under the qudrant i the clutch saftey switch. Is this right
The clutch pedal has a CC switch too (so the CC cuts off when you depress the clutch pedal).
Use your meter to check for 12 volts while cranking being the only product in the connector you seek.
If your SN is like my fox, a blade fuse works great to bridge the connector (for testing only!). And my CSS has two terminals. one terminal had two wires in it and one terminal had one wire in it.
Good luck.
