  • SN95 4.6L Mustang Tech
clutch switch?
  • Thread starter Thread starter bert96
  • Start date Start date Mar 21, 2007
bert96
109
st-jean-sur-richelieu
Mar 21, 2007
  • Mar 21, 2007
My car wont start.It does not not make a noise,it does not crank but i hear the fuel pump.Could it be the clutch switch? if so.how can i bypass this switch?
I NEED HELP ASAP!!!!
THANKS
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 21, 2007
  • Mar 21, 2007
The clutch switch doesn't usually go bad. Have you messed with the stater lately?
bert96
109
Mar 21, 2007
  • Mar 21, 2007
nope
D
Dragstr05
643
Stafford VA
Mar 21, 2007
  • Mar 21, 2007
Starter is a good possibility. Sucks due to its location though.
The easiest thing to do if you can is get down under the car with a multi-meter and probe the power cable on the starter while someone holds/cycles the key. If you're getting voltage, that starter took a poo. If you dont have voltage, you have a problem elsewhere or the mentioned clutch safety switch may also be the culprit.
bert96
109
Mar 22, 2007
  • Mar 22, 2007
Ok,but how can i bypass the safety switch clutch? is it possible?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 22, 2007
  • Mar 22, 2007
With some help try to push start it...I'm thinking if the clutch switch is bad it won't fire up since you have to engage it then disengage after it has fired. The switch is in an open position when the clutch pedal is not depressed is the reason it will fire up if the switch is OK. If it isn't it won't allow the car to run. If it runs then you can get under it and take a look at the wires on the starter. Make sure the ground hasn't worked it's way loose. More than likely you may have a bad stater solenoid.
bert96
109
Mar 22, 2007
  • Mar 22, 2007
Thanks for your help!
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
