L Lbduballstrs New Member Mar 15, 2004 5 0 0 Apr 2, 2004 #1 Apr 2, 2004 #1 every time I push in my clutch it makes a weird whinning noise. the higher the rpms the louder it is. any ideas of what it is?
D Dtowncats New Member Jun 2, 2003 340 0 0 York, PA Apr 2, 2004 #2 Apr 2, 2004 #2 When you push it in or when you let it out? Just making sure because mine whines when I let it out
P PRO50SC New Member Dec 28, 2003 1,012 1 0 Olney, Maryland Apr 2, 2004 #3 Apr 2, 2004 #3 Lbduballstrs said: every time I push in my clutch it makes a weird whinning noise. the higher the rpms the louder it is. any ideas of what it is? Click to expand... Most likely it's the throw out bearing goin bad.
Gravel Member Mar 17, 2004 216 0 16 Bellingham WA Apr 2, 2004 #4 Apr 2, 2004 #4 Whining when clutch is in = Throw out bearing Whining when clutch is out and in neutral = Input shaft bearing noise in the transmission
L Lbduballstrs New Member Mar 15, 2004 5 0 0 Apr 2, 2004 #5 Apr 2, 2004 #5 its when ever the clutch is pressed in it doesnt do it when its out and in neutral
