clutch
  • Thread starter Thread starter 873Stang
  • Start date Start date Jan 28, 2007
873Stang
221
riverside
Jan 28, 2007
  • Jan 28, 2007
whats a good clutch to run??
current is a king cobra
its alright,
and what are good tires that grab for street
HISSIN50
34
129
Jan 28, 2007
  • Jan 28, 2007
Please whip out a sig. Recommendations will vary wildly depending upon what combo you're running. Is the car a driver? Is pedal effort a paramount consideration?
Tire recommendation kinda falls into the same lump.
Good luck.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 28, 2007
  • Jan 28, 2007
honestly for a street car i like the Center Force Dual Frition clutch.
Fett
766
  • Jan 28, 2007
Without knowing what power you are putting down, it will be tough to suggest a clutch.
If this helps, I probably have 250ish to the wheels in my 88 DD, and when I go to the track I beat the snot out of the car. Slicks, dump the clutch at 5500rpms to launch, and my King Cobra has been strong. I would suggest it highly.
ponyboy19
1,640
Jan 28, 2007
  • Jan 28, 2007
I would recommend the C102 10.5" SuperHD Clutch Kit from D&D performance. http://ddperformance.com/ford clutches.htm Pedal effort is just like stock and it holds alot of power. I've ran two of them, t5 and t56, and both were flawless and not to mention super easy on the foot. There is no comparison in pedal effort and holding capicity compared to the stiff King Cobra and it's not grabby at all.
ninety15.0
1,336
  • Jan 28, 2007
SPEC stage II....grabs like crazy
873Stang
221
riverside
Jan 28, 2007
  • Jan 28, 2007
yea my car is stock, feture upgrades will be bbk intake, 70mm throttle body 3:73, so main focus is something the pedle isnt too stiff but grabs and i live in ca so mostly dry out here so i need tires to grab and hook my tires (k106 handkooks) suck monkey balls all they do is spin and spin and spin, 2gear spin spin some more.
V
v8only
2,378
22
49
Jan 29, 2007
  • Jan 29, 2007
that's the worst possible choice for a street car, and especially one with a t5. Those clutches are tranny killers. the weak link in a drivetrain HAS to be the clutch, and the spec clutches are NOT the weak link. Because of that, people with specs wind up blowing their hardware, trannies, ujoints, rear ends, whatever is weakest first.
a certain amount of slip is required. so..... for the poster of this thread, with the future mods considered, I'd just stick with the good old king cobra. can't beat the price, and there is absolutely no reason to upgrade to a better clutch than that. That clutch will hold up to 300 horse, and you won't be close to that figure
Curse
791
El Paso, TX
Jan 29, 2007
  • Jan 29, 2007
I like the SPEC stage 2 on my friends 93 cobra, but v8only makes a good point. I'd rather buy a new clutch than a new transmission.
V
v8only
2,378
22
49
Jan 29, 2007
#10
  • Jan 29, 2007
  • #10
don't get me wrong, I loved the spec too, it sure is a badass feeling gear ripping clutch, and it makes shifting fun. Believe me though, unfortunately there is something to pay for such a stiff clutch though
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
