  • 2.3L (N/A & Turbo) Tech
clutch
  • Thread starter Thread starter t3t4_4g63
  • Start date Start date Sep 19, 2007
t3t4_4g63
94
  • Sep 19, 2007
ok, i just got my tranny pulled out for the rebuild on the svo. now i need to start saving for a GOOD clutch to put back in. i think im just wanting to try to get around 300rwhp out of this car. so what would be a good choice as far as you guys's experiences?
samickguy15
404
Delavan, IL
Sep 19, 2007
  • Sep 19, 2007
Most guys run a stock disk with an upgraded pressure plate. I've heard people grenade Centerforce clutches. I would suggest a Spec pressure plate. Probably stage 2.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Sep 19, 2007
  • Sep 19, 2007
Do you want a high performance clutch, or one that lasts a little while?
I have a Centerforce II (I think it was) pressure plate and clutch disk, which I picked up for around $200. You just need a throwout bearing to go with them, but I've been happy with it so far.
A lot of people run the Spec Stage III, but I've also heard it only lasts 10,000 miles...and for $300-something, screw that.
t3t4_4g63
94
  • Sep 19, 2007
well, i want the clutch to last a while.....this isnt going to be a car that goes out to the track or anything like that.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Sep 20, 2007
  • Sep 20, 2007
Go to clutchnet.com and get a "yellow" disc, use a stock pressure plate, and you'll be good to go.
t3t4_4g63
94
  • Sep 20, 2007
what about a throw out bearing?
t3t4_4g63
94
  • Sep 20, 2007
would you recommend that over Forced4's stage 1 clutch?
Stinger
7,754
24
118
Sep 24, 2007
  • Sep 24, 2007
Are you kidding? The stage 1's torque capacity is 255 (as stated in the title) which is about 100lb/ft less than you'd be making at 300rwhp.
t3t4_4g63
94
  • Sep 24, 2007
DUHHHHHHH!!!!!! i knew that, i was just makin sure you were on your toes!
ok, so i buy the "yellow" disk and leave everything else stock. does clutchnet also sell the rest of the kit stock? or will i have to buy a new kit from Autozone or something and not use the disk?
Stinger
7,754
24
118
Sep 25, 2007
#10
  • Sep 25, 2007
  • #10
You can get a whole clutch kit from clutchnet.
t3t4_4g63
94
#11
  • Sep 26, 2007
  • #11
oh, ok. thanks!
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
