clutch
  • Thread starter Thread starter NewbeewithGT
  • Start date Start date Oct 4, 2007
N
NewbeewithGT
  • Oct 4, 2007
Does anyone out there by chance know the specs for a clutch, stock, on a 94 Gt 5.0? I am looking into putting in a stage 2 clutch and need to know the specs. Thank you
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 4, 2007
  • Oct 4, 2007
Are you talking about the torque specs? If so, it is 24 ft. lbs for the pressure plate to flywheel.
Or are you talking about the diameter? If so, it is a 10.5" clutch disc.
If you have any other questions, check out the link in my signature for a clutch swap. It should help you.
Good Luck.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Oct 4, 2007
  • Oct 4, 2007
Number of splines? Torque for diaphragm-to-flywheel bolts? Torque sequence? Holding capacity by horsepower or torque? What kinda "specs" are you looking for?
N
NewbeewithGT
  • Oct 4, 2007
I appreciate that! One of the clutches i was looking at was asking for the balancer size of like either 28 or 52 oz i believe. Any ideas on which one i would need?
N
NewbeewithGT
  • Oct 4, 2007
I am looking for specs that would help in purchasing a new clutch kit that will go on and work on my car.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 5, 2007
  • Oct 5, 2007
The flywheel and balancer are the only thing you should worry about for balance. And from the factory they are 50 oz, both the balancer and flywheel.
But for a clutch, you do not need that information. A clutch does not come with an imbalance.
Clutch Kit Part Numbers for 86-95 5.0L
You are looking for 10.4-10.5 Inch Clutch Disc – 10 spline – 1 1/16th input shaft!
Ford Racing Heavy Duty Clutch (30%) - FMS-M-7560-A302N
Ford Racing King Cobra (30% - Lighter pedal than HD) - FMS-M-7560-C302N
Centerforce Stage I Pressure Plate (30%) - CF-360048
Centerforce Stage II Pressure Plate (60% more holding power) - CFT-360048
Centerforce Stage I Pressure Plate for 93-95 Cobra - CF-360057
Centerforce Stage II Pressure Plate for 93-95 Cobra - CFT-360057
Centerforce Clutch Disc for Stage I/II Pressure Plate - CTF-381021
Centerforce Dual Friction Clutch for 86-93 (90% more holding power) - CTF-DF021048
Centerforce Dual Friction for 93-95 Cobra (Fits 86-95 but has more clamping force) - CTF-DF021057
Centerforce DFX series for 86-95 (Lightweight Centerforce Clutch Disc) - CTF-LM021057
Spec Stage I Clutch Kit – SF481 (30% more holding power)
Spec Stage II Clutch Kit – SF482 (60% more holding power)
Spec Stage III Clutch Kit – SF483 (100% more holding power)
Centerforce has the lightest pedal in the aftermarket.
Good Luck.
N
NewbeewithGT
  • Oct 6, 2007
Hey i appreciate your help!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox In search of a Spec clutch dimension.
  • PonyGTrider
  • Jun 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2025
PonyGTrider
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
