Clutches
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
I have a center force dual friction clutch now, i'm going to switch it out for a spec stage 2. What do you guy's think of these? Or what do you run that works good? I'm running 301/338 NA at the wheels. peace
john:p
If it is not worn out, I would keep the CF DF. I have a Spec II in my car now and I have had the Centerforce before. I do like the Spec II, as it is not too on/off like the Spec III, but is more on/off than the Centerforce. Overall I really liked the centerforce DF I had in my 89 a couple years ago. It drove like a stocker, but could hold a decent amount of power, and should be handling your power with no problems.
Im in the same power range as you...
Bolt-ons + Vortech blower.
the CF clutch is *ok* but its longevity leaves a lot to be desired.
I found this out after destroying mine in a little less than 6 months... I talked to the guys at Extreme Performance and they said the CF clutchs just dont last that long.. and reccomended Spec because it was what they used.
I'm running a spec stage 1 now and its been like that for 1.5 years now. I prefer it over my CF anyday. The stage II might get a little a annoying in a DD... which is why I opted for the stage 1. It handles all I have and has a little room for more.. so Im sure you would be fine with it too.
