  • 2005 - 2009 Specific Tech
CMVC delete question
  • Thread starter Thread starter xbone
  • Start date Start date Dec 17, 2006
1 of 2 Next Last
xbone
29
  • Dec 17, 2006
Can you just gut the factory butterflies, or do you need to replace the intake plates?
J
Jimp
486
  • Dec 17, 2006
You'll want to replace the plates. They are only $95.
YELLOW42RCODE
346
San Diego, Ca.
Dec 18, 2006
  • Dec 18, 2006
xbone
29
  • Dec 18, 2006
Ok, another question, how does the delete really help power? Seems like the whole purpose of them was to create turbulence for better power at low rpm's, does the removal only help high rpm power?
JTGrant
775
GA
Dec 18, 2006
  • Dec 18, 2006
I can tell you that with the deletes and the brenspeed tune. The car gained power across the whole board. I have not dynoed in a while, but it felt like it had more power everywhere and better throttle response. Also I say no difference in fuel mileage.
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Dec 18, 2006
  • Dec 18, 2006
So, no part-throttle losses?
J
Jimp
486
  • Dec 18, 2006
To me it felt stronger across the board. Part-throttle, full throttle, excellent throttle response. It's the best and cheapest mod I've done.
metroplex
405
SE MI
Dec 19, 2006
  • Dec 19, 2006
If it is all the same, I'm going to keep mine and wait for the FAST intake manifold that should have the CMCV deletes built-in.
N
Norse1974
S.FLA
Dec 25, 2006
  • Dec 25, 2006
metroplex said:
If it is all the same, I'm going to keep mine and wait for the FAST intake manifold that should have the CMCV deletes built-in.[/QUOT
You go ahead and spend 800.00 for an intake to gain a suppossed 40HP!Yes,are intakes are just fine for street/track use!They have been used in upwards of 800-900HP!!!Do the delete plates and spend the rest of the $$$$ on something really worth while.Like suspension or an aluminum drive shaft!JMO though
metroplex
405
SE MI
Dec 26, 2006
#10
  • Dec 26, 2006
  • #10
Or get both: lightweight driveshaft and the intake! :SNSign:
N
Norse1974
S.FLA
Dec 26, 2006
#11
  • Dec 26, 2006
  • #11
I think you missed the point Bro.....
A&B 06GT
54
BAY AREA
Dec 26, 2006
#12
  • Dec 26, 2006
  • #12
does anyone have a dyno sheet of before and after with the delete plates
O
Osiris
I'm married to a crazy, Danish broad
1,643
San Antonio. TX
Dec 26, 2006
#13
  • Dec 26, 2006
  • #13
I installed these plates over the holiday weekend ( got 'em for $65 plus shipping brand new, hehehehehe ) and everything went smoothly, install took about 45 minutes or so.
This morning, on the way to work, cruising about 65 or so, I gave it about 3/4 throttle to pass a car and the car went into fail-safe mode.....Thing just glided to a stop and I about ****. Three turns of the key it started back up and there was no light or any warning. The car ran fine to and from work....
I don't know if the plates have anything to do with that or not. I'm going to hook the predator back up to it and see if it throws a code or anything....All I know is that was pretty scary!
metroplex
405
SE MI
Dec 26, 2006
#14
  • Dec 26, 2006
  • #14
Did you reflash or tune your PCM with a calibration that deletes the IMRC functions?
O
Osiris
1,643
San Antonio. TX
Dec 26, 2006
#15
  • Dec 26, 2006
  • #15
Yes indeedy....
Dynotuned did all my tuning for it....
O
Osiris
1,643
San Antonio. TX
Dec 26, 2006
#16
  • Dec 26, 2006
  • #16
Just ran the codes...last two ( there were several, such as injector circuit open, 1-8 ) were:
Throttle control actuator - forced engine shutdown
Throttle control actuator - loss of power
I cleared the codes and I'll see what it does. If I have to I guess I'll reflash the ECU....
N
Norse1974
S.FLA
Dec 26, 2006
#17
  • Dec 26, 2006
  • #17
Typically you need a custom tune when you install the delete plates just like with L/T headers.Most people I know have the delete plates & L/Ts done at one time so as to avoid visiting the tuner twice!
P
PERTANO
11
#18
  • Dec 26, 2006
  • #18
I just installed my Delete plates this weekend too. Love them!!! The car has no noticeable low RPM power loss, but what it gained in the top end is awesome. It pulls even harder now all the way across the RPM range. I can't wait to get my new rims and tires on it now. The 8's just aren't holding the car anymore.
O
Osiris
1,643
San Antonio. TX
Dec 27, 2006
#19
  • Dec 27, 2006
  • #19
I had custom tunes made to allow for the plates before I installed them.
red05bullitgt
861
Pittsburgh, PA.
Dec 27, 2006
#20
  • Dec 27, 2006
  • #20
I must respectfully disagree.. a custom tune is not required for IMRC delete plates ? I used to have the SCT X-Cal II 9415 preloaded tuner that provided an option under the end user adjustability menu for IMRC delete's
1 of 2 Next Last
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 7:49 PM
General karthief
