CNC Hydraulic Clutch kit for T-5 trans
reyesjo
66
Hey have any of you guys installed a Hyraulic Clutch kit from CNC.. I have a T-5 transmission and did this setup...
At first I could not bleed the slave cylinder, but after hours of tring I finally did it...... However I know have a nasty noise comming from the transmission it sounds like the Throw out bearing and when I engage the clutch it goes away,, and when I put it in reverse it clicks like its not adjusted properly... The Transmission and all the componets are rebuilt or new.
Need some advise if someone know what to do.....
T-5
sorry I have not replied earlier I have been so busy with X-Mass
OK what I have is a the master and slave clinyder mounted on a 1989 T-5 transmission.. the picture will show what I have, the throw out bearing is the stock bearing for a 1989 T-5 tranmission and it was new...
thanks for your reply
