Cobra cluster swap?
IF it is like the 99-04 cars, which I think that it is, you will be able to swap it. The PATS is controlled in the instrument cluster as part of the digital odometer unit. You will need to swap over the digital odometer from your existing cluster to the Cobra cluster and it should work.
When I installed my Bullitt cluster into my GT, that was the only thing I had to swap between the clusters to get it all to work correctly.
