  • 1994 - 1995 Specific Tech
Cobra computer in a gt ?????
  • Thread starter Thread starter Bad Saleen
  • Start date Start date Aug 22, 2004
Bad Saleen
116
  • Aug 22, 2004
I have a 94 gt can i use a cobra computer in my gt withtout any mods
let me know
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
let me know
I'm running the Cobra computer but it requires 24# injectors.
Bad Saleen
116
  • Aug 22, 2004
so i have only to put 24 lbs injector and i can install the computer
let me know
thanx a lot
Zero Signal
2,633
Tucson, AZ
Aug 22, 2004
  • Aug 22, 2004
I've tried running the J4J1 calibration on mine and it would barely run, even after changing the injector slopes. I wouldn't bother since it's timing curves are more conservative than the stock T4MO so you'll probably lose power on a stock motor.
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
let me know
thanx a lot
Yep. The cobra computer is programmed for the 24# injectors but uses the same MAF from the GT which is cal'd for 19#. It adjusts the injector pulse to do this. Running the Cobra computer with 19# injectors would give you a pulse width way to short and the car would fall on it's face.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 22, 2004
  • Aug 22, 2004
I can't resist, sorry...
The stock MAF isn't calibrated. The term "calibrated MAF" is purely an aftermarket creation -- it only exists because without a tuner, the only way to run different sized injectors with the stock EEC is to lie to the EEC about how much air is actually entering the engine. That way it calculates a pulsewidth that is compatible with the installed injectors.
The GT and Cobra use the same MAF, and the EEC has the same curve programmed into it in both cases. There are scalar values in the calibration that specify the flow rate for the injectors.
[/prick mode disengaged]
Dave
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
Prick mode? Naw. How many times have I called someone on a detail, big or small? Besides, you're right.
Slow5.0
2,554
Portland, OR
Aug 22, 2004
  • Aug 22, 2004
OFF TOPIC
HairyCanary please change in your sign that 2nd link because you have two http// on front and we can't open your link with HP/TQ numbers
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 23, 2004
  • Aug 23, 2004
Slow5.0 said:
OFF TOPIC
Fixed, thanks for catching that.
Dave
Slow5.0
2,554
Portland, OR
Aug 23, 2004
#10
  • Aug 23, 2004
  • #10
Dave
NP bro
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
