A few months ago I switched my flywheel and clutch out and had to return the 6 bolt flywheel to get an 8 bolt cobra flywheel the guy at the shop said that my particular block used the cobra crank. I didn't think anything of it at the time just wanted to get my clutch done. Does the romeo blocks have cobra pistons/ rods as well or is it just the crank? Also does anywon know how much HP will my block hold before the limit? I am planning on a turbo setup when I get back from overseas and am debating on spending the money on a shortblock car is a dailly driver as all stangs should be driven. thanks for the info
. The answer is no, our blocks have crappy cast pistons/rods/crank so it's limited to around 400WHP. Anything more and you'll want forged internals.
