Cobra Flywheel Weight??
  • Thread starter Thread starter 4.6LPoppy
  • Start date Start date Jan 21, 2008
4.6LPoppy
Tulsa, OK
Jan 21, 2008
  • Jan 21, 2008
I'm thinking of putting an '03-04 alum Cobra flywheel (2R3V-6375-AA) in my 2000GT. Anyone know its weight? Is is a good flywheel??
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Jan 21, 2008
  • Jan 21, 2008
why not just get a Steel Flywheel made for your GT? The billet ones are only good for auto-x or high hp cars.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 21, 2008
  • Jan 21, 2008
look at his sig
myponyrocks
Apr 18, 2004
1,219
Jan 21, 2008
  • Jan 21, 2008
CobraRed_96_GT said:
look at his sig
doh
4.6LPoppy
Tulsa, OK
Jan 21, 2008
  • Jan 21, 2008
myponyrocks said:
doh
Hey, its OK. Still......anyone know the weight?
LaserSVT
3,546
233
Jan 21, 2008
  • Jan 21, 2008
Do earlier Cobras have them? Sorry not completly :OT:
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 21, 2008
  • Jan 21, 2008
Some run the '03 Cobra clutch & flywheel in thier '96+. Most haven't had any problems. It grips well and has a good feel. You're going to need new pressure plate bolts. The 11" clutch uses a different size. The part number in the Ford computer is wrong (unless you want to find that out the hard way). The part number you need is N808969-S100. They come in a package of 6 from Ford.
You'll really enjoy the aluminum flywheel. Once the tach sweeps past 3500 the motor will rev much quicker than before. Total weight savings from the stock 96-98 stuff is 8 pounds, so 99+ should be the same, and you'll feel every bit of it.
Stock ’96 parts-
Flywheel = 21.5 lbs.
Pressure Plate = 18 lbs.
Clutch Disc = 4.5 lbs.
Total = 44 lbs.
’03 Cobra parts-
Flywheel = 12 lbs.
Pressure Plate = 19 lbs.
Clutch Disc = 5 lbs.
Total = 36 lbs.
I'd post stuff like this in tech tho if you want some solid opinions
4.6LPoppy
Tulsa, OK
Jan 21, 2008
  • Jan 21, 2008
Stock ’96 parts-
Total = 44 lbs.
’03 Cobra parts-
Flywheel = 12 lbs.
Total = 36 lbs.
Ooops. Thought I had put it under Tech. Guess not. Thanks for the good answer though. (I already have a 11" Centerforece Dfx clutch, so I should be good to go there.)
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 21, 2008
  • Jan 21, 2008
well then strap 'er on and let the good times roll
4.6LPoppy
Tulsa, OK
Jan 22, 2008
#10
  • Jan 22, 2008
  • #10
Uh oh. Re-open can of worms. I have read twice now that you cannot re-surface an '03-04 Cobra aluminum flywheel? Is that true?
4.6LPoppy
Tulsa, OK
Jan 22, 2008
#11
  • Jan 22, 2008
  • #11
You can resurface an '03-04 Cobra flywheel if it is not scarred too deeply or burned real bad I've learned. Anyway, I bought a pretty decent looking one for $30 that needs a simple turn (?). So, we'll see how that goes. Thanks guys.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 22, 2008
#12
  • Jan 22, 2008
  • #12
most dont recommend resurfacing any aluminum flywheel, right? It's been done tho
9
97speedster
134
stanwood,wa
Jan 22, 2008
#13
  • Jan 22, 2008
  • #13
My Fidanza has a replaceable steel plate that attaches to the Aluminum flywheel so for $30 i just have to bolt the new one on and no waiting for a machine shop.
4.6LPoppy
Tulsa, OK
Jan 23, 2008
#14
  • Jan 23, 2008
  • #14
Most aftermarket aluminum flywheels for 4.6 have replaceable friction plates. I don't know whether the '03-04 Cobra's is removable or not. I think they may be turning it while on the flywheel. Anyway, a couple have said they have done it and it worked fine. We'll see.
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Saturday at 11:27 PM
Bib36`
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
